Just curious if anyone has input on these two issues: 1.) I've noticed that the Level 1 setting of my HVAC fan is dead. 2-4 work great, just wondering what I sould look at - new switch, bad relay, etc... 2.) I've never had luck with the rear door locks on my SCREW. I have the doors set to lock automatically when I hit 10-15 MPH. Front doors open without issue, but back doors remain locked until either I hit "unlock" or the person grabs the lock pin and pulls it up. I noticed that there are child safety lock setting on the rear doors, but I have those selected to "unlock". Any insight on this matter would be helpful. Thanks!
Iowaredneck is right. Just switch the rear safety lever either up or down, it should have a label right on it. The switch for you HVAC fan speed is easy to replace and the part is inexpensive. Just remove the front cover and pop off the old switch and replace.
