1. Turn the ignition on but don't start the truck. 2. Wait approximately 1 minute for the seat-belt light to turn off. 3. after seat-belt light turns off, buckle and unbuckle the seat-belt 9 times 4. after buckle/unbuckle 9x, the seat-belt light or airbag light is going to blink, after it's done blinking, buckle and unbuckle seat-belt one more time and now the seat-belt chime is deactivated. Note: *In order to do this sequence properly, occupant in vehicle must be by himself in the truck with no other occupants. *All doors need to be closed. *The passenger seat usually has a seat-belt chime sensor equipped so the seat-belt deactivation must be done for that seat as well separately. *Occupant must be in passenger seat in order to do the seat-belt chime deactivation sequence for that seat. *To activate the seat-belt chime repeat the same sequence for each seat and seat-belt chime will reactivate.
Have you done this???I did it and it only disabled my drivers side i cannot get it to work for the passenger side
if you read it it's says *Occupant must be in passenger seat in order to do the seat-belt chime deactivation sequence for that seat.
yes i know im only partially stupid but it still didnt work. I have not tried it in a few months but every time i do it it works until the passenger gets out
maybe not but im gonna go try it again right now. i have tried it many times cause when i go to the farm its pretty ******** annoying if someone is with me.it will usually disable but once i turn the truck off its back.
