2wd to 4wd Conversion: Whats needed?
Discussion in 'Exterior' started by VanoFord, Apr 25, 2011.
  1. VanoFord
    So I am gonna do this by the end of the year. lets make a parts list. I'll start
    Transmission
    Transfer case
    Rear Driveshaft
    Front Drive shaft
    Front axle Housing, including axles, cv's
    Matching R&P
    Knuckles
    Rotors
    4.6L 4x4 ECU
    4hi/lo switch
    Truck is pre-wired for the 4wd switch, just need the switch as mentioned. what have I left out? Thanks!
  2. westtnfx4
    All I can think of is a ton of cash :jester:
  3. Darth Bama
    I have to agree. :jester:
  4. VanoFord
    how so? if i find a wrecked truck but good powertrain, its like $2k tops, which is cheaper then a new truck note. hell, price all that stuff i listed from ebay, its like $2.5k. The ECU is going to be more expensive then the transfer/transmission. I'll also have my transmission to sell for some cash back.
  5. Darth Bama
    :jester:
  6. westtnfx4
    Personally I don't have the time or patience to do something like that. I would simply sell yours or trade it for a 5.4 4x4 screw and be done with it.
  7. iowaredneck
    tons of cash or trade brother, not worth the effort imho
  8. VanoFord
    Look guys, I appreciate the inputs, but this thread isn't WHETHER I SHOULD OR NOT but what is needed to complete this conversion. Its my dime, not yours, so nuff said on that. Thanks for the opinions, but what is needed only? Thanks!
  9. The Batman
    The Batman Rest In Piece
    cold hill ky
    both front hubs...i reccomend a solid axle...drive shaft...transfer case...maybe mounts?...hope your tuck is a unibody...clutch pedal...and make sure the gears match your rear stub...anything else? did i forget anything?
  10. iowaredneck
    donor truck would probably be your best be cause then you get could get everything. you list above seems to be in order after a quick glance, good luck brother
