hey guys, i am looking into buying a RCD lift kit and was wondering if my oem FX4 wheels will still fit or does the kit require aftermarket wheels? thanks
im on my phone right now and cant open the instructions but it should tell you in there if you can keep oem wheels http://www.racecardynamics.com/products/suspensions/ford/fordf1504wd2004/specsheets/ford4wd150.htm
From what I read on the instructions, it says it will accommodate a 17x8 wheel with either a 33 or 37. It did not say that u could not use a factory wheel.
Odds are you wont be able to use stock wheels.If the kit comes with new spindles then you'll might need to get new wheels. You'll have to get wheels with the correct backspacing required for it.
The only way to tell is if you try or can take measurements off of someone elses truck that has that lift. On Rough countrys site it says you cannot use stock wheels and I called them and they said they wouldn't fit, ...........but my stock wheels fit fine when I had that lift, no problem
