Here's updated list of I still need. blue seatbeats C6 dust cover radiator support for 390 390 radiator for automatic 67 sun visors power brake brackets 390 flexplate driveshaft for a auto c6 2wd w/8ft on a 1/2 ton window weatherstripping door weatherstripping shift indicator window 390 engine motor mount hardware 390 dizzy hold down clamp w/bolt 390 coil brackets 390 vaccum and bracket for dizzy front cab mount supports cab floor supports floor pans rocker panels(maybe)
Here's a updated list 67 spare tire carrier with hardware blue seatbeats radiator support for 390 390 radiator for automatic 67 sun visors 390 flexplate driveshaft for a auto c6 2wd w/8ft on a 1/2 ton window weatherstripping door weatherstripping shift indicator window 390 engine motor mount hardware 390 dizzy hold down clamp 390 radiator fan shroud 67 headlight doors aluminum/chrome ones heater control valve horn relay horn(s) horn wiring harness 67 door jam wiring harness 67 wiring harness no cargo switch brake warning light switch cargo switch delete panel 68 390 engine wiring harness
What do you have? I think the flexplates are the same. Not sure on the radiator or radiator fan shroud.
390 settin in the pasture in a 60s ltd. front cap and heads are off of it. Sent from my SCH-I500 using Tapatalk
Is the 67 truck like the 66? Cause my dad used to race a 66 with a 429 and he may have some parts layin around. Sent from my SCH-I500 using Tapatalk
390 car and truck engines are little different. 1)car 390 heads wont work with headers and oil adapters bracket bolts up different direction. If it has automatic radiator get dimensins and part # off of it so I can see if it will fit. Thats if it any good. No, 67-72 same body style. The 360 and 390 werent used in trucks til 68.
Dang lol but ill look sometime heck idk if it even has a radiator Sent from my SCH-I500 using Tapatalk
