Coil Over Replacement
Discussion in 'Exterior' started by iFX4, Dec 13, 2011.
  1. iFX4
    iFX4 Chief
    Florida
    I am looking into replacing my coil overs...they are pretty rough and I think they are causing the front end to sag a bit...
    Should I just get some through Ford or is there a site where there are aftermarket ones?
  2. TxFx04
    well yeah theres aftermarket like king coilovers, cst coilover but you'd have to sell the rigid for a pair
  3. iFX4
    iFX4 Chief
    Florida
    Yea I saw those....F that.
  4. TxFx04
    then theres icon coilovers
    Why do you have to have coilovers? Do you need new shocks or springs or what? I'd just get some bilsteins and call it good
  6. iFX4
    iFX4 Chief
    Florida
    Well I got rancho rs5000 less than a year ago. Guess I could look into the quick lift
    Sent from my iSmarty 4
  7. VanoFord
    the rs5000's are nothing compared to the quicklifts. i abuse the hell out of my front end suspension, hitting the huge asphalt speed bumps at 20-25. front end is smoother than the rear (thats thanks to the AAL making it stiff on rebounds). what you would spend in a set of coilovers, you can reshock your whole truck w/ 2 quicklifts in the front and 2 9000xls in the rear for LESS. AND, the new quicklifts come preloaded, just a simple bolt on application. when i purchased mine, i had to do the swap, and thats a pain at times.
  8. cowboy
    you could look at rockauto.com as well. They have the preloaded assemblies as well.
  9. formerflyboy
    formerflyboy Junior Member
    Illinois
    I put the QuickLifts on my 04 and love them. Don't be surprised if you have to replace the stabilizer end links when you put the coil-overs in. If the links have been in for a long time they're likely to break when you try to remove them to lower the LCA to fit the coil-overs in.
    Sent from my DROID BIONIC using Tapatalk
  10. Darth Bama
    Whatever you do, I wouldn't buy them from Ford. They're overpriced imo.
