Edge Evo shift points
Discussion in 'Engine & Performance' started by backwoodscountryman, Jan 24, 2011.
  1. backwoodscountryman
    Backwoods
    OK so on my Edge Evo for shift firmness i use 12 for all. My question is for my shift points what are some good number to run on Tow(87) tune?Thats the tune i mainly use.Any suggestions would be great.
  2. TFIDDLE
    ^I am also wondering this for my XCal 3 just in case that I ever want to change.
  3. ak_cowboy
    I'm running +7 for mine. Are you worried about sshifting too hard with a trailer or something?
  4. THEPRODJECT01
    THEPRODJECT01 MARKK
    odum , ga
    I always run high octane fuel on the performance setting, I shift at 5,500 rpms in 1st , 5,250 in second , and 5000 in 3rd
    I used to shift at 6000 in 1st just for the Hell of it but I turned the rpms down
  5. backwoodscountryman
    Backwoods
    Not all.Just wondered if i should up my shift points since i am running 12 for my shift firmness for all gears.Thats all.
  6. ak_cowboy
    Oooh I see what you mean now. I have my first 2 at 5000 and 3-4 at 4900. I found a HP chart and I think these keep me in the powerband the best. Peak power is at 4300 I think.
  7. backwoodscountryman
    Backwoods
    Ok i will try those first and play around from there.But will going that high cause me to have a decrease in mpg's?Or will it stay about the same?
  8. cowboy
    Your shift points should not change your mpg's enough for you to notice.
  9. ak_cowboy
    It should stay the same because those are WOT shifts. For standard shift points I have them stock, except 3-4 is at -3, so it goes into overdrive sooner.
