Fixing My Scratches - Turtle Wax Hard Compound
Discussion in 'Exterior' started by VanoFord, Sep 11, 2012.
  1. VanoFord
    Just like the title says, i've started to get rid of all my scratches from off-roading last year finally. using Turtle Wax hard compound - heavy duty. applying by hand then using my 10" polisher to buff it to a shine. most of the light "fingernail" scratches come off in 1-2 applications. the HUGE scratches that run the length of my door are taking 5-10 applications. you can notice in this pic that there are 2 marks running the length of the doors on the front, but the top scratch starts to fade once it is on the back door.
    that is the line i have been focusing on. i think it will be blended by tonight, and i will start on the lower one, back door, tomorrow. one door at a time. i'll update pics as I finish every night.
  2. Northwoods4x4
    Northwoods4x4 BangBro
    Chula Vista CA
    Nice! I might have to try this to get some of my starches out
  3. cowboy
    Nice work man. :waytogo:
  4. TxFx04
    very nice Vano, now if only you could buff out dents :facepalm:
  5. VanoFord
    it gets those "fingernail" scratches off right away. I'll take other shots when I get home to show the difference when using this stuff.
    thanks again bro
    you got a dent? :shocked:
  6. Stangshcky12
    PA
    Might have to give this stuff a shot
    Theres some bad ones on my 350 and girlfriends cummins
  7. iowaredneck
    sweet, might have to check this out when you get done
  8. VanoFord
    so here are the pics from yesterdays buffing. first the equipment:
    tutrtle wax heavy duty rubbing compound, few microfiber applicators (if you dont have a secondary power tool to apply), and a 10" buffer for polishing. this stuff works even if applying by hand but the buffer for polishing is a must.
    first dampen your applicator and apply some as so:
    you'll want to apply in a circular motion centered along the scratch line. if using a power tool for applicator remember to let the tool do the work. dont push down and do not stay on corners/edge lines for too long or it will distort them. now, some before and after pics.
    fender before:
    during:
    after:
    you can notice that the long scratch that ran the length of the hood line is GONE! the scratch coming up to the hood line is slightly lighter. that was a deeper one so i had to do it 2 more times using lots elbow grease.
    compound should be applied to clean, cool surface out of direct sunlight. i'll be focusing on my bed in front of my tail light tonight. this will be the 4th day in a row i have washed this side of my truck as all road grime each day needs to be removed too. let me know what you guys think. i'll keep uploading my progress, less detail more pics.
  9. iowaredneck
    Nice job
    Sent from my SCH-R530U using Tapatalk 2
  10. 2011F150
    2011F150 Full Access Member
    Venus,TX
    Looking good Vano i used the same stuff on my 02 FX4 back in the day that stuff is a miracle worker. Keep it up!
