The fuse is just behind the bumper on the engine side wall behind the driver-side headlight. It's about halfway between the headlight and the fog light (height wise). It's just a little ceramic oval with a plug on the bottom. Pull the plug off and your DRL's will no longer come on.
I found 2 different things on a 06. Either that plug is behind the headlight or fuse 13 under the hood is for drl
ill chck both...didnt realize i had fuses under my hood...i thought they were only inside on my passanger side kick panel
Its either behind the headlight or behind the bumper. You will have to look for a plug that has a blank plug in it. Its a 2 wire plug if I am correct.
