Got my tow mirrors from Tasca Ford. Install is very easy...only took about 20 mins/side. Start out by removing the 2 screws at the bottom of the door panel. Pop the rectangular cover on the door handle off. This exposes the 2 screws, remove them, then remove the handle unit. Pop the cover with the window/lock controls off. Disconnect the harnesses Remove the one screw here Pop the speaker cover off. Remove the 4 speaker screws Disconnect the harness to the speaker Take this rubber thing off and pull the 2 plastic tabs off
The panel is ready to be removed. Pull up on it to do this. Now remove the 3 nuts from the mirror bolts. Disconnect the harness. The mirror isready to be removed. It just pulls off Installed on passenger side vs standard mirrors.
sweet! they look awesome! i hate taken door panels apart though...prob only thing that will keep me from upgrading mine to two mirrows! i dispise door panels!
These were actually really easy. No fussing with it. Ford did good with these 150s. My '02 Stang, well that's a different story. Cheaper parts suck.
