I've tried everything
Discussion in 'Exterior' started by Dawgfan54, Jan 16, 2012.
  1. Dawgfan54
    Dawgfan54 Full Access Member
    I can't get the chrome off this. I used acetone on the blue of the emblem and that came off easy. I then tried painting it red with spray paint and it didn't really stick, so I sprayed it again and the paint just cracked up.
    Idk what to use to remove this chrome so the paint will stick... Any ideas?
  2. Bee89
    Bee89 Super Moderator
    Miami, Florida
    Sandpaper ?
  3. jlyoung08
    yea jus scuff it up and spray with self etching primer
  4. VanoFord
    Get some 300 grit. Rough it up a lil (just some scuffing). Spray it w/ some self etching primer. Let that set for 2-3 hrs. Then apply the color paint you want it to be.
  5. Bdons-SD
    it probably cracked because of the acetone. clean it with lacquer thinner, let it dry, prime then pain.
  6. ak_cowboy
    ^ ditto. Sand it down, clean it, let it dry, prime it, then paint it :peace:
    Or just paint it with some bedliner :jester:
  7. Dawgfan54
    Alright I went to ace and bought some 320 grit sandpaper, and some primer, I'm gonna sand it down and try it again and see what happens. Thanks y'all.
  8. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    hey did u try sanding it and maybe some primer? then paint
    thats what id do:birgits_tiredcoffee
  9. VanoFord
    Did you buy just Primer or Self- Etching Primer?
  10. Eric of Memphis
    munford tn
    hahaha ^ this guys a comedian :jester: i was ninjad
