I do have it completely disconnected....but I should just take it off or they won't cover any of it....lol!
lightbar made your truck stall? there is no way that could happen. something else caused the stall. the amount of amps that lightbar is pulling is nothing compared to what the truck is putting back out through the alternator. if you dont have high beams, have you tried swapping out bulbs? maybe the high beam filament went out in those. its happened to me before...
I didn't wanna read all the pages so if this has been said, then just completley ignore this, but the white wire is for your reverse white led's in the light bar. If it doesn't have reverse then its just the 4 pin connector
No, I know the light bar didn't make it stall. I just thought I'd throw that out there. Good thought on the lights, I was going to try that, just hadn't gotten around to it yet
Put the original headlights and fogs back in and everything is fine Took the light bar off too....just in case PS. Thanks for all the help!!!
