New headers and y pipe (NEED HELP)
Discussion in 'Engine & Performance' started by eagle18, Jul 22, 2011.
  1. eagle18
    eagle18 Junior Member
    Valdosta GA
    i have been looking around for new headers and y pipe i just ordered and k&n cold air intake system and throttle body spacer im wanting to upgrade my headers take the cats off if possible and a new y pipe with it can anyone help me i dont really know much in this departement.
  2. TwentyTenFX4
    Mobile, AL
    wish i could help man. i know about as much as you do on this kind of stuff.
  3. jlyoung08
    Get long tubes instead of shorties if possible...I've heard guys say shorties don't do a lot
  4. 97madness
    Long tubes, run high flows so you shouldnt throw any codes. And true duals setup would be the best idea.
  5. 07Fx2
    07Fx2 Full Access Member
    Oklahoma
    Your in my area now. What year? What motor? 5.4 3v go with long tube, high flow cats, 3" Y pipe, 3" piping to a single in or single in dual out. Preferably magna flow, borla, corsa, or dynomax bullets. Stay away from crapmasters.
    4.6 2v, 3v they only make shorty headers for the 04-10which on my 04 I went with jba shorties, high flow cats from magna flow, tru-x pipe from magna flow, duel in duel out magna flow. 2.5 piping. Now since your going with a y pipe. Run 2.5 piping. Mandrel bent for smother flow. Same goes for the 5.4. This will increase your low end torque. True duels will boost your top end. Hope this helps. Got any more questions ask
  6. 07Fx2
    Oklahoma
    I spent around 1,500 for my old exhaust set up. I'm looking at 2000 for this new one.
  7. 07Fx2
    Oklahoma
    If you have 04-08 5.4 3v they run lean from factory. So when you install that cai, you need custom tunes. Gryphon or sct. If you run it with no custom tunes. Your going to have engine detonation. Which is going to cause problems. Throttle body spacer, send that crap back our engines are fuel injected not carbureted. It won't do anything but be an expensive paper weight. Believe me I was in your position at one time.
  8. 07Fx2
    Oklahoma
    same thing applies to 2009+. I just noticed your pic on your profile.
  9. iowaredneck
    long headers and no throttle body spacer, waste of time and money
  10. cowboy
