painting interior parts?
Discussion in 'Tech Info' started by mustangwarrior, Mar 9, 2011.
  1. mustangwarrior
    NE Ohio
    for painting plastic pieces, how should i go about it,
    thinking scuff, paint, clear, right? or should i use an adhesion promoter?
  2. yz85rider2002
    bedliner FTW. no prep work necessary
  3. mustangwarrior
    NE Ohio
    the only thing i'm doing is the long black trim pieces in the dash, and you still need to prep bedliner or it will flake off, but i know painting plastics doesn't always work well either
  4. yz85rider2002
    yeah good point
  5. Darth Bama
    Adhesion Promoter is your friend...
    Scuff, clean, spray AP, prime (optional), paint.
  6. iowaredneck
    what bama said
  7. VanoFord
    Krylon Fusion. No prepping of any kind for painting on plastics. You can even use this as a primer, then paint whatever you would like over it, since the Krylon will bond w/ the plastic, then the new color to the Krylon. I used this stuff w/ my interior, going from grey, to black, and its held up in the texas heat for 2 yrs now, no flaking or fading of any kind. I even used some flat black paint over the top of it on the top of the dash cuz it gave a wicked glare from the sun.
  8. mustangwarrior
    NE Ohio
    thanks, i was thinking about spraying it and while it was still wet trying to do a marble effect with plastic wrap, then clearing it for smooth gloss finish
  9. ex4banger83
    go for it man...should look good
  10. yz85rider2002
    itd look good with the marble on it
