Well when I put my truck in reverse there is a loud poping noise from somewhere in front of the driver side. I'm affraid its the front differential but I'm not positive. It only does it in reverse. Any ideas on what it could be. Ill check the fluid in the front differential 2morrow.
does it do it in 4x4 too???...does your 4x4 engage rough or pop when engaged??...does it only do it when you bach up or does it do it when you turn in reverse???
put it through those paces and see what it does...that way we can narrow it down to the most likely culprit...keep me posted on it ok?
having the same issue so curious to see what this may. mine is not bad at all though anad i have not even tried to figure it out yet.
