Possibly lifitng....
Discussion in 'Lifted' started by iFX4, May 13, 2011.
  1. Auburnfan400
    Hartselle, Alabama
    Yea forreal, i bought a BL last year and wanted to get the gap guards and they were an extra $90. I said thanks, but no thanks
  2. iFX4
    iFX4 Chief
    Florida
    see there is an 03 screw riding around and you can see HUGE 4" aluminum blocks plain as day in the rear....im just like :facepalm:
  3. Auburnfan400
    Hartselle, Alabama
    Thats why i didn't put my BL on my truck
  4. J.Wal
    Wit the 4" rancho you can run stock rims. With the 6" most Lifts say run 4.5" bs. To measure your bs take the rim off the truck, lay it face down. Lay a flat object on the rim, so that it is roughing the rim not sitting off the rim and on the tire. The distance from the lip of the back side of the tim to the mounting surface is your back space. I put a thread in the wheel section that shows charts for bs and offset by wheel depth and size.
    J.Wal
  5. J.Wal
    I am fixing to put on the 6" rough country and eventually hope to do a 3" on that, gears and 38s
    J.Wal
  6. UtahFord
    I'm going to eventually just do a BL with a leveling kit
  7. rrogers
    get 6" rough country 1300, 3" bl 300, make your own gap guards and be rocking one sick ride on 38s
  8. ak_cowboy
    I haven't heard anything good about body lifts. And actually read a couple 4x magazines where they had articles on how to remove body lifts...
  9. UtahFord
    What are the cons I say its just hearsay
  10. rrogers
    the body lift of today is different than the ones they use to make. bl use to be crap and was nothing but blocks a new bolts,the ones today if properly installed are great. follow the instructions exactly to torque and you will be pleased.
