Question?
Discussion in 'Exterior' started by rrogers, Nov 28, 2010.
  1. ak_cowboy
    hmmmmm, thats no good. I'll look into this and see what I come up with.
    Did you get a bi-xenon kit? It seems that the single bulb kits have this problem because of wattage issues or something. All I can think of is to double check all the connections, especially the grounds.
  2. VanoFord
    So I had this happen to me after I installed my HIDs. And it eventually made my fog light toggle not work all together. Someone told me that it was the High Beam indicator switch, on the column, that might have went out. I have yet to switch it out, just adding another spin on what it might be. I obviously still have the problem...
  3. rrogers
    glad to know im not alone in this
  4. VanoFord
    now, when you engage your fogs, does your dash light HB come on, then stay on after you disengage the fogs? or does it go away when the fogs are off again?
  5. rrogers
    It goes back off when i turn the fogs off
  6. VanoFord
    yea, sounds just like mine. i've been betting on either the HB switch on the column, or my fog/light switch cluster went out. Can you hear the relay "pop" on and off when you turn the fogs on and off?
  7. rrogers
    i have not paid much attention to that. i did replace the relay thinking maybe it was that but no luck. its not really a problem just kinda annoying and thought i would fix it before it caused another problem
  8. VanoFord
    Yea, same here. I just bypassed it and ran my fogs through a toggle til I got some time to tear into the electricals.
  9. rrogers
    Great idea i may do the same
