Radiator Drain Plugs
Discussion in 'Tech Info' started by Roush PSD Interceptor, Dec 21, 2010.
  1. Roush PSD Interceptor
    Go to drain the radiator and surprise, the end of the drain plug breaks off.
    The plastic becomes brittle after years of heating cycles. This plug is the same part # on our 2001 3.0 Ranger, 2000 7.3 PSD F250 and by parts cross reference numbers is the same on a 2001 F150 with a 4.6 liter.
    I found a "Motormite" replacement # 61127 for $3.89 plus tax at a local replacement parts store.
    The old broken off plug can be removed with a 1/4 hex socket or the end of a flat blade screwdriver that is similar in size, be ready with a catch pan or bucket for the antifreeze flood coming from the drain plug fitting.
    Uploaded with ImageShack.us
  2. The Batman
    The Batman Rest In Piece
    cold hill ky
    it happens to the best of us man!
  3. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    mine broke off so i jacked the drivers side and just undid the bottom hose clamp...then you can pull the broken plug without fear since its already drained
    just an fyi
