So i ended up lifting my truck more
Discussion in 'Lifted' started by UnleashedFord, Dec 4, 2010.
  1. UnleashedFord
    UnleashedFord wheres the dirt?
    Mission Hills, SoCal
    dont worry guys ill post up pictures tomorrow but today i ended up lifting my truck more at the shop, i have the stage 2 procomp lift and i put a 2in spacer ontop of the strut and i think the height is too much for 35x12.50x17 tires...do you guys think the spacer is too much ontop of it? or will i be fine?
  2. yz85rider2002
    i hope not. im going to be running the 6 inch kit, with a 2 inch spacer on top
  3. UnleashedFord
    well thats what i did and it seems like the top upper control arms are at a pretty bad angle, but never know might be ok because if some of you know the guy nickname larrw1 from the forums also known as larry. his upper control arms are at a really bad angle and little worse then how mine are now and he says he is perfectly fine
  4. yz85rider2002
    id run it for a while and see if you notice a difference
  5. UnleashedFord
    well i need to get an alignment done again no matter what but if i am going to adjust my coils why get an alignment done twice, ill post some pics tomorrow and see what you guys think
    my friends and i think it looks better now
  6. yz85rider2002
    did you put an AAL on the back to level it out?
  7. westtnfx4
    :rocking: yeah pics please ....
  8. che22879
    che22879 Big Dog Che
    Los Angeles
    Where the pics at?
  9. RIV Customz
    RIV Customz I recycle parking tickets
    About 9' up
    If your angles LOOK bad, they ARE bad. They may be fine for a while but you know it's gonna put more stress and wear and tear. Get some after market UCAs.
  10. Big'un
    i tryed to run my leveling kit with my 6" rough country and it put my top a arm in a bad bind .... heres pics .... i had to take the levelin kit off
