So i ended up lifting my truck more
Discussion in 'Lifted' started by UnleashedFord, Dec 4, 2010.
  1. agjake11
    agjake11 Suck my tailpipe
    Rosenberg/Baytown TX
    ^^ im with stupid :jester:
    your angles are horrible
    plus couldnt you have just cranked the coils more rather than adding the spacer
  2. Raevsky97
    Raevsky97 bagged 97 f150
    Derby, Kansas
    haha looks like mine only opposite :birgits_tiredcoffee
  3. UnleashedFord
    UnleashedFord wheres the dirt?
    Mission Hills, SoCal
    599?!?! now way i can afford that right now
    i didnt wanna mess with the coil
  4. agjake11
    that how you get the front lift. you need to loose the coils or take the spacer off and tighten the coil. post the pics on f150 or search there youll see why. your coils do the same thing the spacer adds
  5. UnleashedFord
    if i shorted the coil it would have less room to travel and it would of heated up really fast by hitting itself so much, so i can soften it up about about an in maybe
  6. agjake11
    whered you come up with the heat bs haha.
    if you crank it it will stifen it up and lift it more which will cause a rougher ride, loosening it does the opposite but if you leave it how it is your gonna be destroying the upper ball joints and limiting your travel still
  7. UnleashedFord
    that was my idea, but Leo (OgTerror) told me about the heating of the coils so idk
  8. agjake11
    if you were going over whoopdies maybe but as you drive the coils wont heat more due to being cranked more and having less stroke.
  9. UnleashedFord
    i think im gonna end up dropping the coils down about an inch for right now, if i drop it an inch will i be able to still fit 36x13.50?
  10. agjake11
    cant say how much tire you can fit but your wallet will thank you and your ass will too for not having such a rough ride.
