It says 2007, but I'm pretty sure this applies to all 04-08s. Though they left out the screw/6.5' for some reason... 2007 Ford F150 Specifications Powertrain/Chassis POWERTRAIN 4.2L V-6 4.6L TRITON V-8 5.4L TRITON V-8 Engine Type V-6 iron block, aluminum heads V-8 iron block, aluminum heads V-8 iron block, aluminum heads Bore/Stroke 3.81 x 3.74 3.55 x 3.54 in 3.55 x 4.17 in Displacement 256 cu in, 4196 cc 281 cu in, 4606 cc 330 cu in, 5400 cc Compression Ratio 9.2:1 9.4:1 9.8:1 Fuel Injection Sequential multi-port electronic Sequential multi-port electronic Sequential multi-port electronic Valvetrain OHV, 2 Valves per cylinder SOHC, 2 Valves per cylinder SOHC, 3 Valves per cylinder, Variable Camshaft Timing Power 202 hp @ 4350 rpm 248 hp @ 4750 rpm 300 hp @ 5000 rpm Torque 260 lb-ft @ 3750 rpm 294 lb-ft @ 3500 rpm 365 lb-ft @ 3750 rpm Oil Capacity 6 qt 6 qt 7 qt Coolant Capacity 19.7 qt 20.0 qt 20.7 qt Transmission Type 5-speed manual/4-speed automatic O/D 4-speed automatic overdrive (4R70E) 4-speed automatic overdrive (4R75E) Gear Ratios 5-speed manual 4-speed automatic O/D 4-speed automatic O/D 1st 3.90:1 2.84:1 2.84:1 2nd 2.25:1 1.55:1 1.55:1 3rd 1.49:1 1.00:1 1.00:1 4th 1.00:1 0.70:1 0.70:1 5th 0.80:1 - - Available axle ratios 3.31:1 / 3.55:1 / 3.73:1 / 4.10:1 SUSPENSION Front 4x2 Coil-on-shock, long-spindle double wishbone independent, cast aluminum lower control arm 4x4 Coil-on-shock, long-spindle double wishbone independent, cast aluminum lower control arm Rear 4x2 Hotchkiss-type non-independent live, leaf springs and outboard shock absorbers 4x4 Hotchkiss-type non-independent live, leaf springs and outboard shock absorbers STEERING Type power rack-and-pinion Overall Ratio 20.0:1 (regular cab/supercab 132.5? wheelbase) 17.0:1 (supercab 144.5, 163? wheelbase/supercrew) Turning circle, curb-to-curb see Dimensions and Capacities BRAKES Front 13.0-in vented disc Rear 13.7-in vented disc Assist type Vacuum, ABS WHEELS AND TIRES Base wheel and tire 17-in steel, P235/70R17, All-Season Largest tires available 22-in aluminum, P275/45R22 All-Season Dimensions and Capacities Regular Cab SuperCab SuperCrew Styleside Flareside Styleside Styleside Styleside Flareside Styleside Styleside 6.5ft 6.5ft 8ft 5.5ft 6.5ft 6.5ft 8ft 5.5ft 4x2 4x4 4x2 4x4 4x2 4x4 4x2 4x4 4x2 4x2 4x2 4x4 4x2 4x4 4x2 4x4 EXTERIOR Wheelbase 126.0 126.0 126.0 126.0 144.5 144.5 132.5 132.5 144.5 144.5 144.5 144.5 163.0 163.0 138.5 138.5 Overall length 211.2 211.2 211.2 211.2 229.8 229.8 217.8 217.8 229.8 229.8 229.8 229.8 248.4 248.4 224.0 224.0 Overall height 73.7 75.6 73.6 73.8 75.6 74.0 76.5 73.5 75.6 75.6 73.5 75.6 73.4 75.4 73.5 76.0 Overall width 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 78.9 Track width, front 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 Track width, rear 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 67.0 Cargo box length 78.8 78.8 78.8 78.8 97.4 97.4 67.0 67.0 78.8 78.8 78.8 78.8 97.4 97.4 67.0 67.0 Width (max) between wheels 50.0 50.0 50.0 50.0 50.0 50.0 50.0 50.0 50.0 50.0 50.0 50.0 50.0 50.0 50.0 50.0 Inside Box Height 22.3 22.3 22.3 22.3 22.3 22.3 22.3 22.3 22.3 22.3 22.3 22.3 22.3 22.3 22.3 22.3 INTERIOR Seating capacity 3 3 3 3 3 3 5/6 5/6 5/6 5/6 5/6 5/6 5/6 5/6 5/6 5/6 Headroom Front 40.9 40.9 40.9 40.9 40.9 40.9 40.9 40.9 40.9 40.9 40.9 40.9 40.9 40.9 40.1 40.1 Rear - - - - - - 39.6 39.6 39.6 39.6 39.6 39.6 39.6 39.6 39.6 39.6 Legroom Front 41.3 41.3 41.3 41.3 41.3 41.3 41.3 41.3 41.3 41.3 41.3 41.3 41.3 41.3 41.3 41.3 Rear - - - - - - 32.7 32.7 32.7 32.7 32.7 32.7 32.7 32.7 39.0 39.0 Hiproom Front 65.4 65.4 65.4 65.4 65.4 65.4 65.8 66.5 66.5 66.5 66.5 66.5 66.5 66.5 63.1 63.1 Rear - - - - - - - - - - - - - - - - Shoulderroom Front 66.5 66.5 66.5 66.5 66.5 66.5 66.5 66.5 66.5 66.5 66.5 66.5 66.5 66.5 65.8 65.8 Rear - - - - - - 66.7 66.7 66.7 66.7 66.7 66.7 66.7 66.7 65.8 65.8 Fuel capacity (gal) 26.0 26.0 26.0 26.0 27.0/ 35.7 27.0/ 35.7 26.0 26.0 27.0/ 35.7 27.0/ 35.7 27.0/ 35.7 27.0/ 35.7 27.0/ 35.7 27.0/ 35.7 30.0 30.0 Turning circle, curb-to-curb (ft) 41.8 41.8 41.8 41.8 46.4 46.4 43.6 43.6 46.4 46.4 46.4 46.4 51.2 51.2 45.1 45.1 All Dimensions are in inches unless otherwise noted. Weight and Towing (Pounds) Regular Cab SuperCab SuperCrew 6ft 8ft 5ft 6ft 8ft 5ft 4x2 4x4 4x2 4x4 4x2 4x4 4x2 4x4 4x2 4x4 4x2 4x4 WEIGHT Base curb Weight 4.2L 4615 - 4747 - - - - - - - - - 4.6L 4708 5004 4840 5138 4979 4297 5065 5363 - - 5176 5476 5.4L 4811 5109 4944 5241 5151 5452 5169 5471 - - 5281 5577 5.4L payload pkg - - 5125 5413 - - - - 5501 5849 - - Payload capacity 4.2L 1830 - 1850 - - - - - - - - - 4.6L 1890 1740 1910 1760 1620 1570 1580 1530 - - 1570 1360 5.4L 1790 1680 2050 1650 1740 1640 1820 1670 - - 1710 1560 5.4L payload pkg - - 3020 2670 - - - - 2640 2290 - - GVWR 4.2L 6500 - 6650 - - - - - - - - - 4.6L 6650 6800 6800 6950 6650 6900 6700 6950 - - 6800 6900 5.4L 6650 6850 7050 6950 6950 7150 7050 7200 - - 7050 7200 5.4L payload pkg - - 8200 8200 - - - - 8200 8200 - - Maximum Towing Capabilities - Conventional Towing Maximum Loaded Trailer Weight (Lbs.) - Automatic Transmission Regular Cab 4x2 4x4 Engine Axle Ratio GCWR (Lbs.) 126 - inch wheel base 144.5 - inch wheel base 126 - inch wheel base 144.5 - inch wheelbase 4.2L SEFI V6 3.55 10000 5200 5100 - - 3.73 10500 5700 5600 - - 4.6L Triton SEFI V8 3.55 11500 6600 - 6200 - 3.55 11700 - 6700 - 6400 3.73 12000 7100 - 6800 - 3.73 12200 - 7200 - 6900 5.4L Triton 3-valve SEFI V8 3.55 13000 8000 - 7700 - 3.55 14000 - 8800 - 8500 3.73 13500 8500 - 8200 - 3.73 15000 - 9800 - 9500 4.1 15300 - 11000 - 9500 Manual Transmission 4.2L SEFI V6 3.31 7200 2400 2300 - - 3.55 8500 3700 3600 - - Maximum Towing Capabilities - Conventional Towing (1) Maximum Loaded Trailer Weight (Lbs.) - Automatic Transmission Super Cab Super Crew 4x2 4x4 4x2 4x4 Engine Axle Ratio GCWR (Lbs.) 132.5 - inch wheel base 144.5 - inch wheel base 163.0 - inch wheel base 132.5 - inch wheel base 144.5 - inch wheel base 163.0 - inch wheel base 138.5 - inch wheel base 150.5(2) / 138.5 / 150.5(2) 4.6L Triton SEFI V8 3.55 11500 6300 - - 6000 - - - - 3.55 11700 - 6400 - - 6400 - 6300 6200 / - / - 3.73 12000 6800 - - 6800 - - - - 3.73 12200 - 6900 - - 6700 - 6800 6700 / 6500 / 6400 5.4L Triton 3-valve SEFI V8 3.55 13000 7700 - - 7400 - - - - 3.55 14000 - 8600 - - 8300 - 8500 8400 / 8200 / 8100 3.73 13500 8200 - - 7900 - - - - 3.73 15000 - 9500 - - 9300 - 9500 9400 / 9200 / 9100 3.73 15000(3) - 5800 - - 5600(4) - - - 4.1 15300 - - 9500 - - 9300 - - (1) Reduce GVWR and Max. Trailer Weight by 500 lbs. on models with 18" or 20" Wheels. (2) Late Availability (3) Optional Ford Harley-DavidsonTM Package (4) AWD
